Mini Connected hoe werkt dat .... (nieuwe software)
Kees en Annet
Racende reporter
20 okt 2010, 19:34
Ik zal het vast openen, en dan kan iedereen hier zijn bevindingen en opmerkingen kwijt :wink:
eerst wat stukken uit de andere topics plaatsen
Kees en Annet schreef: Even een stukje van Motoringfile (26-07-2010)
MINI Connected Delayed
MINI Connected is being delayed. But it’s for the right reasons. According to exclusive sources MINI is pushing back the option to improve the software quality so the performance is perfect from day one. What they do not want to do is release something that requires a software update later for optimal performance.
But what of the timing? The word from our sources is that MINI is expecting this push back the options by “weeks instead of months” from the 2011 launch date. One caveat with all of this news is that we’ve only confirmed this delay for the US market. We’d expect all markets would be in tandem with this but (as we’ve learned in the past) the US market can, at times, play by their own rules when it comes to extra quality control measures.
For a refresher, lets take a look a closer look at the option. MINI Connected allows your iPhone to Connected the outside world to your MINI. The option adds a new 6.5” hi-resolution screen (the same as on the 2011 Nav system), Comfort Bluetooth (6NE) with Smartphone prep (6NF), a Combox control box (interface the iPhone with the car), Voice recognition (620), and a joystick controller to access all features just as the MINI Navigation uses. Currently, only the iPhone is supported, but the Android and Blackberry Smartphones are being planned as well for a later launch.
Also, you can disconnect your iPhone or iPod from the cable and still listen to your music via Bluetooth wirelessly. This means you can literally walk away from the car and control your music with your iPhone from 20 feet away. And with the new system, the only cable you need is the standard iPhone cable that came from Apple.
Diving deeper into MINI Connected’s online functions, let’s take a look at what can come through to your car. A audio feature called Webradio allows you to search for radio stations around the world by country, genre and so forth. From there just select the station and it’s streamed into the car.
You can also access RSS feeds (like MotoringFile’s for instance) with MINI Connected. Simply select playback and voice recognition will read out the text to you and continue on beyond what you see, playing back the entire article. While stopped, you can also read the whole news article.
The much maligned Mission Control is also a part of MINI Connected and features over 3,500 sayings. You can pick and choose what you want to hear and adjust the “enthusiasm level” by selecting your driving theme. In addition, the upgraded system will have a “MINIMALISM” Analyzer that gives you real-time hints for optimum fuel efficiency. Perhaps the most important feature of Mission Control? You can turn it off.
Another new feature is Dynamic Music. It allows you to choose from several beats and based on your driving conditions, can increase or decrease the intensity and rhythm, allowing you to literally create your own track while driving.
Also incorporated is Google Local Search. Here, you can search for common items such as restaurants, fuel stations and even post offices by location, type and even business name. When a result is found you can select it and if they have a phone number and address listed online, Google will display it right in your car.
And if you are a Facebook and Twitter fan, you can read recent posts just like the news feeds where limited text is shown while driving, but can be played back to you thanks to text-to-voice technology. If you are stopped, then you can read more. If you need to respond, MINI Connected can help you post with pre-populated responses based on information that it knows. For instance, you can simply choose from several sentences that will include things like temperature and vehicle speed. And if you have NAV, MINI Connected can even include your destination and current location. You could post something like this with just one twist and one click- “Hey guys, it’s 3:00 PM and I’m in my MINI driving Southbound to Main Street on this warm 74 degree day.”
Lastly, there’s option 7L5, MINI Connected with Navigation that also features Real Time Traffic Information. The new NAV system uses an internal solid state memory so DVDs are not needed. Maps can be updated through a USB port in the glovebox. Best part? It’s going to be only $1,750, which is cheaper than last year, but adds everything mentioned above with MINI Connected.
aansluiting via de kabel
of via de snap-in
seirv schreef: 08-08-2010 Meer Mini connected info is te lezen op de mini site.
http://www.mini.com/com/en/connectivity ... ted_EN.pdf
Kees en Annet schreef: 18-08-2010 en een stukje over MINI Connected
Product information MINI Connected Functions & Settings
pimmy schreef:Hierbij informatie over het Harman/Kardon geluidssysteem:
http://www.mini.harmankardon.com/en/veh ... index.aspx
Tnx!!
Laatst gewijzigd door Kees en Annet op 21 dec 2010, 20:32, 1 keer totaal gewijzigd.
Kees en Annet
Racende reporter
20 okt 2010, 19:41
nog een bericht van
Maarten CH schreef:Volgens de Duitse site is het onderdeel van Mini Conected
http://www.mini.de/news_events/models/m ... index.html
Volgens MotoringFile
Maarten CH schreef: Muziek zou ook over bluetooth moeten werken. Misschien heb je hiet wat aan:
Kees en Annet schreef: dit staat er in de handleiding die bij de Countryman geleverd wordt
als je goed leest staat er: dat het ook met de snap-in adapter mogelijk moet zijn. (ik weet niet of dit wel werkt) :roll:
let er wel op dat de Snap-in volledig bedraad is (€130,- Music snap-in adapter)
en niet de normale uitvoering die alleen voor de telefoon is (ongeveer € 90,-)
ze zeggen in de MINI prijslijst vanaf 40,- :s
Kees en Annet
Racende reporter
20 okt 2010, 22:43
Kees en Annet schreef:MINI Connected Walk-Through
even de tekst erbij van MOTORINGFILE
But we’ll let Robert walk you through the system. Here’s a quick video of Robert and myself going through Connected. (video after the break)
It was interesting to hear from him first hand about the MINI Connected delay for the US market. The official reason is that MINI was waiting to finalize the additional features (listed below) before they brought the option to their largest market. MINI didn’t think Connected was as compelling as it needed to be with just we radio, RSS and Twitter.
For the record here’s the current list of features on the European app (which will be updated when the US version comes out):
•Web radio
•RSS news reader
•Twitter client (with auto populated tweets optional that know location, temp and time)
And now here’s the full list of features that the US app will have (combined with the list above):
•Google local search
•Google send to car
•Dynamic music (creates music based on your driving and what your doing (ie turn signal, acceleration, cornering)
•“Minimizer” (tells you how to optimize the way you drive for better efficiency)
•(original feature) Web radio
•(original feature) RSS news reader
•(original feature) Twitter client (with auto populated tweets optional that know location, temp and time)
Now that we’ve talked about the technology and what we’ll have when the US version of the app and option is released, let’s talk about how well MINI Connected actually works.
Of the three the RSS reader is the one that most cries out for either a larger screen or a different system interface. Because of the space used for the MINI infotainment interface navigating through the text (or even choosing the car to read the text) can be a little cumbersome.
Twitter on the other hand is extraordinarily simple. It allows your to choose between posting your own update or choosing from three canned tweets that contain GPS, speed or temperature data to creating something vaguely compelling (ie I’m motoring on I94 and it’s 54 degrees).
By far the most interesting of the featuring in 1.0 is the web radio. The system (much like iTunes radio option) allows you to choose one of thousands of web radio stations all over the world. Even MINI has a handful of stations from Europe that stream music wirelessly. It’s incredibly compelling and would kill the need for Sirius in my next car.
All the functionality of course relies on your iPhone’s connection to broadband data. But what does this mean for owners without unlimited data plans? We spoke to MINI about this and based on some quick calculations they’ve done, even if you used MINI Connected to stream video five days a week for two hours a day (a pretty long commute) you’d only reach around 1GB. AT&T for example has two plans; one with 250MB and another with 2GB. Clearly the 2GB will be a good idea with MINI Connected. Of course that doesn’t count many iPhone owners who are still grandfathered in with old unlimited plans.
The app currently supports five languages and will be expanding in 2011. And speaking of expanding MINI didn’t give anything away in regards to what platform is next. However if we had to guess (from reading body language) it would likely have to be some form of Android. Of course what form and what flavor of Android it’ll be compatible with is anyone’s guess. After that we’d guess a stripped down version would be available for Blackberry.
zie hier voor verdere gegevens http://www.motoringfile.com/2010/10/19/ ... more-13706
en de vertaling ervan (let niet op de schrijffouten (gedaan met Google vertalen) :P
Het begon allemaal met die simpele iPod-connector die in 2003 debuteerde in BMW's en MINI's. Het idee van het aansluiten van de technologie van buiten de auto en laat hem aan de macht van de infotainment centrum in het dashboard. Fast forward zeven jaar en heeft eindelijk genomen MINI een enorme sprong met MINI Connected.
In feite sprong is niet eens het juiste woord. In Connected werkelijkheid is een keerpunt in de automotive-technologie voor het simpele feit dat het duurt voor ontwikkeling van software uit van zeven jaar automotive cycli. En even belangrijk het introduceert app mentaliteit die het mogelijk maakt voor software-ontwikkeling te richten op nieuwe functies die zijn gebouwd op robuuste platform. Dat betekent dat de Mini kan op maat Connected app en je auto in de toekomst de functionaliteit voor wat daarna komt in de wereld van de technologie. Wat gaat er om warm te worden in 2013? We hebben geen idee. Maar in 2013 MINI MINI Connected kunt bijwerken en hebben het daar voor u klaar.
Of u kunt dan denken aan het op deze manier; Connected Hiermee MINI gerelateerde functionaliteit gedreven te worden door je iPhone en vervolgens weergegeven op nieuwe prachtige mini hi-res scherm alles terwijl wordt gecontroleerd door de joystick centrum. Het neemt de telefoon uit je hand en maakt de auto de interface voor je leven.
Op de recente persintroductie van de 2011 Mini-gamma, hadden we een kans om walk-through met BMW MINI Connected Senior Engineer Robert Passaro (een van de leidende ingenieurs van MINI Connected). Robert niet alleen gesproken met ons op via elke functie, maar gaf ons wat achtergrondinformatie over de technologie en waarom het werd gebouwd. Het idee (zoals hierboven genoemd) is alles over de auto van de technologie ontkoppeling.
Maar we laten het Robert wandelt u door het systeem Hier is een korte video van Robert en ikzelf gaan door Connected.
Het was interessant om te horen van hem de eerste hand over de MINI Connected vertraging voor de Amerikaanse markt. De officiële reden is dat MINI was wachten op de extra functies (zie hieronder) af te ronden voordat zij brachten de mogelijkheid om hun grootste markt. Verbonden MINI had niet gedacht dat was zo dwingend als het moest worden met slechts we radio, RSS en Twitter.
Voor de goede orde hier is de huidige lijst van functies op de Europese app (die zullen worden bijgewerkt als de Amerikaanse versie komt):
• Webradio
• RSS nieuwslezer
• Twitter-client (met een optionele automatische bevolkt tweets weten dat locatie, temp en tijd)
En nu hier is de volledige lijst van functies die de VS app (in combinatie met de bovenstaande lijst) hebben:
• Google Local Search
• Google Verzenden naar auto
• Dynamische muziek (maakt muziek op basis van uw rij-en wat je doet (dwz richtingaanwijzers, versnelling, bochten)
• "Minimizer" (vertelt u hoe u het optimaliseren van de manier waarop u rijdt voor een betere efficiëntie)
• (Original functie) Webradio
• (Original functie) RSS nieuwslezer
• (Original functie) Twitter-client (met een optionele automatische bevolkt tweets niet weten die locatie, temp en tijd)
TomTom
20 okt 2010, 23:09
@Kees&Annet
Hebben jullie mission control op jullie Countryman?
Was best wel benieuwd.....
Kees en Annet
Racende reporter
21 okt 2010, 00:15
TomTom schreef:@Kees&Annet
We hebben het nog niet kunnen vinden, het zou een onderdeel van MINI Connected zijn (staat al eerder in dit topic) , maar dat hebben wij nog niet aan de praat, want wij hebben wel een Snap-in 3GS (maar die is niet volledig bedraad komt uit onze BMW 335i)
We wachten nog totdat de uitgebreide bedrade Music Snap-in er is van de iPhone 4. ( 84 21 2 199 393 ) dus we zijn tot die tijd aangewezen op de Y-kabel (USB en 4-aderige jack naar iPhone) ( 61 12 0 440 812 ), en die gaan we zaterdag ophalen bij de dealer...
Maarten CH
Re: Mini Connected hoe werkt dat ....
21 okt 2010, 20:44
Kees en Annet schreef:Ik zal het vast openen, en dan kan iedereen hier zijn bevindingen en opmerkingen kwijt :wink:
Goed idee! Thanx!
Kees en Annet
Racende reporter
23 okt 2010, 12:34
Gisteren even een iPhone 4 gekocht :lol:
want met die van Annet 3GS werkte MINI Connected al
en gelijk vanmorgen uitgeprobeerd in de auto (met de orginele iPhone usb-kabel)
en alles werkte. (zie foto)
Ik had ook net getankt met de auto, dus er zit nog 47ltr in
en je kan gelijk zien dat we met de Countryman pas 736km hebben gereden :wink:
Maarten CH
12 nov 2010, 20:43
Hi Kees & Annet
Heb je al wat meer ervaringen met Mini connected en de iPhone interface? Klopt het dat je de album covers mooi in beeld krijgt 8) ?
Ik heb de handleiding van onze aankomende Mini nu thuis liggen maar heb ook niks kunnen vinden over "Mission Control"... Ik zal het morgen ook nog eens navragen want ik moet toch naar de dealer om de zomerbanden weer even te laten monteren.
paddo
12 nov 2010, 20:59
Ben ook benieuwd naar de ervaringen van het Mini Connected systeem. OK, leuk dat je buiten de auto je km's enzo kunt bekijken maar de overige functies vind ik niet echt spannend en/of meerwaarde hebben. RSS en google local search voegt weinig toe, zeker niet als je je aandacht nodig hebt voor het rijden en in stilstand kun je de iphone natuurlijk gebruiken. Webradio kan handig zijn maar persoonlijk heb ik geen (internet) zenders die ik mis. Twitter? Boeiuh :D En mission control lijkt mij al zeer snel te irriteren :s :mrgreen:
Al met al voegt het naar mijn mening te weinig toe, zeker als je kijkt naar de benodigde investering. Uiteraard een persoonlijke mening, wellicht dat er anderen zijn die er laaiend enthousiast over zijn ?
seirv
22 nov 2010, 21:46
Efficiency is definitely a core value for MINI. Here we have MINI taking that to another level with the MINI Minimalism Analyzer. It’s a core feature of the upcoming updated MINI Connected App that lets you analyze and optimize your driving for maximum efficiency. As of this posting, it’s not in the US Apple App Store yet, but we’ll keep an eye out. Beyond the eco-nerd goodness of being able to optimize your driving for max MPG, this is a great example of the kind of ongoing, expanded functionality that the MINI Connected system brings to the car. So if you’re on the fence about shelling out the $1000 for MINI Connected, think of it this way: you just might make that money back in fuel savings with the help of this app*.
bron: MotoringFile
Laatst gewijzigd door seirv op 22 nov 2010, 23:21, 1 keer totaal gewijzigd.
22 nov 2010, 22:58
Dus als je op het hek over beschietingen uit de $ 1000 voor MINI Connected
Hier is echt niet door te komen.
Plaats volgende keer maar gewoon de Engelse tekst :lol: :lol: :lol:
seirv
22 nov 2010, 23:22
bedankt voor de reactie, de snelle kopieer actie met de chrome gaat niet altijd goed.. ik zal beter opletten.. :(
TomTom
23 nov 2010, 21:16
Ik heb begrepen dan je met de Ipod/Iphone kabel ook video kan afspelen op de display? Heeft iemand dat al eens zien werken? Wellicht leuk om eens een uitbreiding te zien met lcd schermen in de hoofdsteunen.... Voor de mede passagiers....
Maar ik draai door....
Maarten CH
07 dec 2010, 20:48
Na een paar weken wachten hebben wij onze Mini gekregen en hier mijn eerste ervaringen met Mini connected.
Ik heb een iPod touch dus ik heb de Mini connected app niet kunnen proberen maar de iPod interface wel.
Er zijn dus twee mogelijkheden om muziek van je iPod (touch) of iPhone af te spelen. 1: Via het Mini connected menu of 2: Via externe apparaten.
Mini connected:
Via Mini connected wordt de display overgenomen door je iPod en kan je je muziek/podcast/audio boeken zoeken zoals je gewend bent:
Als je bv albums kiest dan krijg je een lijst met albums mooi met album cover waar je door heen kan scrollen:
Eenmaal wat gekozen staat de album cover, naam, naam van het album en van de artiest in beeld. Grootste nadeel... de klok is weg.
Externe apparaten:
Via Externe apparaten kan je ook je iPod kiezen waarbij je dezelfde functies hebt maar dan meer in Mini stijl. Ziet er ook mooi uit maar werkt iets omslachtiger vind ik. Eenmaal een song gekozen staat 10 seconde de naam, naam van het album en de artiest in beeld en daarna de album cover:
Hier kan je ook video of vodcasts afspelen maar alleen als je stil staat. Tijdens het rijden wordt alleen het geluid weergegeven.
Video weergave gaat perfect maar het geluid loopt 3 seconde achter :?
Al met al vind ik het een super interface en hoop hem snel een keer met de iPhone app te kunnen testen.
Muziek afspelen via bluetooth werkt ook maar dan is er geen mogelijkheid om een playlist/album te selecteren en worden de titels niet weergegeven in het scherm. Mocht iemand nog andere details willen weten dan hoor ik het wel :D
Kees en Annet
Racende reporter
21 dec 2010, 20:29
Sinds een paar dagen is er een uitbreiding op de app van MINI Connected (nml. 1.3.3.)
hij werkt echter alleen op 4.2.1 dus niet op 4.1 wat er bij mij opstaat (wordt dan ook niet aangeboden bij de Updates van de App Store)
(dus gelijk maar op de Iphone van Annet gezet, daar staat versie 4.2.1. op).
en het menu van MINIMALISM Analyser
en als je hem in de auto aansluit met de Y-kabel, is het menu ook uitgebreid
dit is het verdere menu van MINIMALISM Analyser
en het zoekmenu van Google TM zoeken
nu nog een keer uitproberen....
:wink:
