ALTA MCS R56 tuning.
11 mei 2007, 12:01
@Kaj,
Quote van Alta over de open filter:
If you haven't seen THIS, PLEASE READ HERE. Part way down you can see the intake info.
Yes you are a little wrong (I am saying it in a nice way, so please don't take that the wrong way). We have done lots of testing with temps (notice the probe behind the filter) that the filter sees in that posistion.
First off the turbo heat shield is removed only to show the DP off. It needs to be installed on the car to keep the hot air away. With it removed during a test, the temps were about 80 degrees above ambient.
Secondly there is quite a bit of air flow throught that area of the car with the OEM scoop STILL installed. The temps we measured were not too much warmer than ambient, but they were warmer. The reason for the temps being reasonable is because there isnt much radient heat coming from the back of the motor, it all comes from the front.
Our intake was designed to remove the scoop, this is why the filter is place where it is placed. Also we use the OEM fresh air scoop to get more fresh cool air into the filter area.
So with the scoop removed, the temps were much better (and this was just using the dyno fans which don't represent the air it sees driving down the road) and needless to say they are not much. Also all of our intake tests were with the hood down to ensure as much as a real world result as possible.
The gains we saw by removing the scoop, were not huge but a few HP. Every little bit makes a difference in the end! Because we gained a good amount of HP, we were very happy.
That being said we had a few tricks up our sleeve to make it even better (not tht it would actually make a difference), and we have true cold air box planed. But there is a cost vs function issue that arrises. We didn't want to come out with a $500 intake system that would scare people away. Things like a special scoop for the under side of the hood to blow on the filter was eliminated because of how much cool air is flying around the filter.
I hope that answers your question/concern.
Lijkt me dus mee te vallen qua vermogenverlies. Een gesloten systeem is natuurlijk altijd beter, maar ik vind het geluid echt super van een open systeem! (vooral bij een turbo). Alta is ook bezig met een gesloten systeem. Misschien iets voor in de toekomst :)
Hier een voorbeeld van een R56 met open filter (aan het einde is het goed te horen).
Laatst gewijzigd door Maaij op 11 mei 2007, 12:38, 2 keer totaal gewijzigd.
Sid
11 mei 2007, 12:12
wat een herrie :mrgreen:
11 mei 2007, 12:17
CooperS-lightningblue schreef: Even nog wat vraagjes vanuit mijn kant, heb er namelijk nul verstand van:
- Wat doen die ALTA Boost tubes?
- Bij de BOV krijg je toch die sis bij het schakelen?
- Wat the hell is en doet een downpipe?
De Alta boost tubes zorgt voor iets meer geluid (geluid wordt niet gedempt zoals bij de OEM slangen).
Veel sterker en dus veiliger (siliconen vs rubber). Beter flow en natuurlijk erg gaaf om te zien 8)
De BOV zorgt inderdaard voor het geluid. Als je alleen voor het geluid wilt gaan moet je deze gebruiken icm de OEM BOV.
De downpipe is het stuk voor de uitlaat (wat naar de turbo gaat). Hier valt de meeste winst uit te halen!
Groter diameter met de high flow cat. Dit zorgt voor een veel beter doorstroming, maar niet goedkoop ben ik bang.
@Coen, voor mij geen universele dump valve. Ik wacht nu op de Alta :)
Laatst gewijzigd door Maaij op 11 mei 2007, 13:26, 1 keer totaal gewijzigd.
11 mei 2007, 12:28
Sid schreef:wat een herrie :mrgreen:
Kwaliteit is ook erg slecht. Het gaat om het idee :)
Laatst gewijzigd door Maaij op 11 mei 2007, 12:34, 1 keer totaal gewijzigd.
Sid
11 mei 2007, 12:34
ze zijn iig bezig met leuke spulletjes daar bij alta :)
11 mei 2007, 12:45
Terecht dat jullie wachten op ALTA... damn wat een mooie spullen :D
11 mei 2007, 13:20
Ben bang dat je zoiets toch in het echie moet horen! :wink:
Sid schreef:ze zijn iig bezig met leuke spulletjes daar bij alta :)
Het lijkt wel sinterklaas! :mrgreen:
Voor mij hoeft er niet zo'n dumpvalve op. Ben daar niet zo van. Misschien op de lange termijn ooit eens een proberen, maar heb er geen plannen mee.
Sid
11 mei 2007, 13:36
Ik wil:
- inlegfilter
- uitlaat
- boost tubes
als we allemaal tegelijk bestellen moéten we wel korting krijgen! :mrgreen:
Laatst gewijzigd door Sid op 11 mei 2007, 13:39, 1 keer totaal gewijzigd.
11 mei 2007, 13:52
Als de prijzen en levertijden bekend zijn kunnen we aan de slag :)
Sid
11 mei 2007, 15:53
speciaal voor maaij ;)
11 mei 2007, 16:13
Sid schreef:Ik wil:
- inlegfilter
- uitlaat
- boost tubes
Dat lijkt me wel ja! Is inmiddels al een aardig lijstje:
2x ALTA panel filter (Sid, CooperS-lightningblue)
5x ALTA 3” Catback Exhaust (Maaij, Sid, CooperS-lightningblue, erce, kaya)
1x ALTA BOV and BOV Plug (Maaij)
2x ALTA Intercooler Diverter (Maaij, CooperS-lightningblue)
2 of 3x ALTA BOOST tubes (Maaij, Sid en misschien CooperS-lightningblue)
1x ALTA open filter (Maaij)
1x ALTA Downpipe (Maaij)
Nou nog prijzen erbij zodra die bekend zijn. Dan kunnen we het rondmaken nadat we uiteraard iedereens uiteindelijke bestelling hebben opgenomen. :mrgreen:
320d touring
BBQ hulpkok
11 mei 2007, 21:18
Ja, en waar staan wij dan ? :evil: :evil: :mrgreen: (voor de catback)
11 mei 2007, 21:35
@320d touring:
6x ALTA 3” Catback Exhaust (Maaij, Sid, CooperS-lightningblue, erce, kaya, turbootje)
Voilá! :mrgreen:
turbootje
11 mei 2007, 21:40
:lachuh Nou staat ie er zelf nóg niet bij! :mrgreen:
MINI..what else?! :))
320d touring
BBQ hulpkok
11 mei 2007, 21:47
