HELPPPPPP mijn iphone gaat niet meer aan, is mijn batterij overleden?
Gister gewoon uitgezet met een bijna lege batterij , toen ik hem vanmorgen wilde opladen kreeg ik voor 2 sec het appeltje te zien en daarna was het weer weg, hij reageert ook niet als ik hem aan de laptop leg, wie o wie helpt mij.
Het grote iPhone topic!
- coendek
- Stoepsleutelaar
Ook dat doet hij niet meer . Ik heb het al meerdere keren zo geprobeerd.
EDIT: Met deze manier is het me na een paar uur proberen gelukt:
15-MIN SOLUTION: CONNECT TO ITUNES AND REBOOT 3 TIMES TO AVOID RESTORE
So this has happened to me more times than i can count, and I've recovered both my phones (2G + 3G) using this method. I've seen some people in this thread allude to this solution but let me just spell it out completely and hopefully this will save you a few restores on your phone.
1. Connect to iTunes via USB. Do not disconnect for rest of these steps. iTunes may appear frozen or stuck with spinning beachball....this is okay, do not Force Quit iTunes. I tried a few times w/o it being connected to iTunes and it doesn't work.
2. Once connected, hold Home + Power until screen blinks then Apple logo comes back up.
3. Wait until Apple logo dims slightly (~5 minutes or less). Do NOT reboot until the apple logo dims.
4. Hold Home + Power again until it reboots and Apple logo comes back up.
5. After 2 min or so, the phone may vibrate once or twice. Continue waiting for the full 5 min until Apple logo dims slightly. iTunes at this stage MAY recognize the phone...do not sync or do anything in iTunes.
6. Hold Home + Power for the 3rd time until it reboots. Phone may vibrate again after 2 minutes or so. Eventually you'll break into your Home screen.
Hope that helps and let me know if it does.
Apparently what causes this endless loop is that the SpringBoard crashes upon launch (over and over again) and launches CrashReporter on the phone itself. It goes into an endless loop until somehow iTunes while connected via USB triggers some sort of fix on the SpringBoard or its preferences/database.
Meer lezen: http://www.onemorething.nl/community/to ... z0nF9RG9AW
- Blont-007
- NMC Legend
laptop moet leggen en dan tegelijker tijd de homeknop indrukken en dit werkt voor het moment
hij is nu aan het resetten.
Maarten de hele morgen liggen laden, nu had Rick op het net gevonden dat je de usb snoer aan deMaVaEe schreef:@ Ida
Gewoon even een tijd aan de oplader leggen en dan nog eens proberen.
- Blont-007
- NMC Legend
Uhm mijn telefoon komt van jurgen maakt dat nog een verschil!MaVaEe schreef:Ja maar je hebt jailbreaken (Wat op dit moment bij elke iPhone kan) en je hebt unlocken zodat je met een andere simkaart dan een Tmobile kaart kan gebruiken. Dit kan niet meer als je gewoon update naar de laatste versie.
- MaVaEe
- Koeien-teller
(Zeg dat dan meteen!
Ok dan maakt het geen reet uit en kan je gewoon updaten naar de laatste versie.Blont-007 schreef:Uhm mijn telefoon komt van jurgen maakt dat nog een verschil!MaVaEe schreef:Ja maar je hebt jailbreaken (Wat op dit moment bij elke iPhone kan) en je hebt unlocken zodat je met een andere simkaart dan een Tmobile kaart kan gebruiken. Dit kan niet meer als je gewoon update naar de laatste versie.
