TK: NM Power Module/Tunebox F56 S-JCW
Spruitstuk, uitlaat, veren, schroefsets, verlichting, bumpers, spoilers etc. te koop, plaats het hier (uitsluitend MINI-onderdelen).
HanDavinci
09 jun 2020, 18:38
Te koop, een drie maanden oude NM power module voor de F56 S/JCW's.
Van de NM site:
NM Engineering Power Module is a device that easily allows the most able person to upgrade the performance of their new MINI Cooper F56  without reducing the reliability or integrity of the engine, clutch, and driveline. This is the simplest and best alternative or option to chip tuning. The NM Power Module is an all-new proprietary tune box designed specifically for the F56, not some rebranded 3rd party product for the BMWs. It is a plug and play box that intercepts the T-MAP sensor and can be installed or removed within minutes without any detection. The electrical components are housed in a billet aluminum enclosure which is protected from the elements and is designed and manufactured to be positioned within the engine bay of your vehicle. The wire harness is manufactured using automotive quality wiring which is both oil and heat resistant, and has the same OE water proof connectors as used on your engine.
Features:
Two-position switch:
LOW: 91+ Premium Fuel (+23HP/+23TQ)
HIGH: 100+ Octane Fuel (+44HP/+34TQ)
 Functions:
Allows ECU to remain in control of boost
The actual boost is increased by a precise amount
Boost is increased in a gradual, progressive fashion
Correct Air/Fuel mixture maintained from the wideband O2 and closed-loop mode of the ECU
Ignition timing optimized by the ECU
Retain factory engine safety protocols
Not affected by ECU reprogramming by the dealer
Plug-and-play intercept at T-MAP sensor connector location
Installation or removal can be completed in a few minutes
No trace Power Module was ever thereafter removal
Power Module can be sold or transferred to another vehicle of the same engine type.
One Year Warranty
Het werkt uitstekend. Plug & play en na het wisselen van de modes is de auto binnen 5km aan de nieuwe waarden gewend. Ik doe hem weg omdat ik toch voor een volledige stage 2 remap ga.
Ik heb zelf meer betaald vanwege de import, maar €250 euro lijkt me een nette prijs.
Ophalen omgeving Twente of verzenden op risico en kosten koper.
Groetjes,
Han da Vinci
Sent from my Pixel 4 using Tapatalk
Laatst gewijzigd door HanDavinci op 09 jun 2020, 18:38, 1 keer totaal gewijzigd.
Dutch
Re: TK: NM Power Module/Tunebox F56 S-JCW
06 feb 2022, 21:58
Dag Han,
Is deze Piggy bank al verkocht?
Terug naar “Te koop aangeboden: Exterieur”
